My iPhone keeps turning off!
Johnny apple
Mar 12, 2008
104
NYC
every day about once a day my iPhone keeps shutting off without me knowing it and i have to keep resetting it just to turn it back on... anyone have any idea whats going on?
chrismmm
Dec 27, 2007
612
Gwinnett, Georgia
how do u know it shutting off? is it rebooting or just sleep mode?
go to setting, general, set autolock to never
Johnny apple
Mar 12, 2008
104
NYC
cause when i go to use it its unresponsive and the only way to turn it back o is either to reset it or plug it into my computer
chrismmm
Dec 27, 2007
612
Gwinnett, Georgia
when it goes into sleep mode and u want to use it. do u try to use the home button or something else to wake it up?
electoman
Sep 20, 2007
127
Atlanta, GA
Mine does the occasional restart. It will be playing along and then just the Apple logo. Weird.
Johnny apple
Mar 12, 2008
104
NYC
no its not jailbroken complety stock and i sometimes use the home button to awaken it
psylichon
Oct 31, 2007
16,591
751
41
Philly
Please define "unresponsive" and "reset" in the contexts to which you're referring. Is the phone freezing? Or going to a blank screen from which the home button does not awake? When you're "resetting" it, are you turning it off and on again or just back on? Your wording leaves a bit to confusion.
Johnny apple
Mar 12, 2008
104
NYC
ok when i mean unresponsive i don't mean freezing i mean its shutting off and the only way to turn it back on is to do a soft reset
psylichon
Oct 31, 2007
16,591
751
41
Philly
Well, you can't do a soft reset when the phone's already off, you're just turning it on. That's what's confusing me. So, are you just turning it back on?
psylichon
Oct 31, 2007
16,591
751
41
Philly
So what are you doing then? To me a "soft reset" is pressing the lock button until the red slider appears at the top, then sliding it off, then pressing the lock button again to turn it on. Another way to turn it off would be to hold down the home and lock button for 5 seconds. Holding them 7 seconds will then turn the phone on again.
I just can't quite visualize your situation. The phone is on, you're doing something, all of a sudden... blank screen? Then you... what?
Johnny apple
Mar 12, 2008
104
NYC
lol no i have my phone on and maybe after a couple of hours when i go to make a call or something its suddenly off then it seems that the only way to turn it back on is to do a hard reset...
(i got confused before with the soft reset)
psylichon
Oct 31, 2007
16,591
751
41
Philly
hehe, yer killin me here. What do you mean by "hard reset"? If the lock button is unresponsive, what else are you doing to turn it on?
Johnny apple
Mar 12, 2008
104
NYC
thats all doing im not sure whats happening but those are the buttons im pushing to turn it back on
psylichon
Oct 31, 2007
16,591
751
41
Philly
no because it wont work if i only push the sleep wake button
Well then this statement is confusing. I think you're referring to the home button in this quote?
Regardless, this is not ordinary behavior for a stock iPhone. I would go to settings/general/reset and hit "reset all settings". You will, of course, have to redo your settings after this.
If that doesn't change things, a restore through iTunes is in order.
psylichon
Oct 31, 2007
16,591
751
41
Philly
if i reset settings that wouldn't delete anything right?
No, the only thing that gets affected here is stuff in the settings page... auto-lock time, screen brightness, contact sort order...that sort of stuff. You'll just have to step through all those categories and put them back to how you want them. Takes a minute at the most.
Johnny apple
Mar 12, 2008
104
NYC
well thanks a lot you been very helpful i think im gonna have to restore on iTunes though
psylichon
Oct 31, 2007
16,591
751
41
Philly
Yeah I wouldn't be surprised. Good luck with it, and let us know how it goes.
