My iPhone temperature it's super hot
kayta
Oct 18, 2013
Help me my iPhone 4S temperature it's super hot while I'm using and when it's chagrin also I don't know why is happening this? And how I can solve this problem ?
Sent using iCafe app
28,400
5,532
How hot are we talking here? Truly hot or just very warm? Is it hot enough to fry an egg? Does it burn your hand? Is it too hot to tolerate while holding it causing you to have to set it down? What apps are you running when it gets hot?
kayta
Oct 18, 2013
It's really hot that I can't hold on my hand ): al the battery gets down very quickly. Like 6-8 hours do you know what can I do ?
28,400
5,532
6-8 hours of usage is good. 6-8 hours of standby is not. Which were you referring to? Does it get hot during normal usage with apps such as email, messages and safari or does it only get that hot during intense games?
Try a hard reset. If that doesn't work, restore it. If it still does it you'll need to take it to Apple to have the battery checked.
RoofMonkey
Jun 21, 2010
8,891
2,057
If it truly gets so hot you can not hold it in your hand, DO NOT keep charging it. In all honesty I wouldn't even have it inside my house.
That's the retired Firefighter in me speaking.
If it is getting warmer than usual, follow what @Europa said to try.
kayta
Oct 18, 2013
Oh thanks @RoofMonkey ill. Do it and yes. @Europa it's really warm when I'm chatting or playing games
Dec 15, 2008
5,386
340
Pensacola, FL
You should probably take it in to Apple if you have one nearby, or take it to an authorized seller to get it looked at, but only if it continues to occur often.
I have not had this happen on any of my iPhones besides when it was in the sun. Now, my laptop is a completely different story. It is normal for a laptop to heat up when watching a video or playing a game.
kayta
Oct 18, 2013
Thank you to everybody . I will go an authorized Apple center .
Today I'm happy because the battery wasn't too hot and during a couple of hours more :)
28,400
5,532
Did you try restoring it? You should do that before you go to Apple.
Sep 26, 2013
It seems something wrong with the battery. Please the solution when the problem was solved.
Goodtimekid
Jan 28, 2012
My iPhone 4s fell 3 meters onto concrete surface. It still works
On the same day the iPhone updated the IOS 7 version
Now my phine gets extremely hot that i cannot hold it, when charging
This has never happened before
Could it be from the fall or the update
U speak of doing a hard reset
How does one accomplish reset
28,400
5,532
Yeah, the drop might have damaged the battery. You'll want to get it looked at if it's getting that hot.
Pressing the home and power buttons at the same time for a few seconds will do a hard reset.
Goodtimekid
Jan 28, 2012
The fall damaged the camera which caused short circuit somewhere causing the battery to overheat
Result
New camera. New battery
iPhone 4S is as new again
LOVE MY iPhone
dmoskaluk
Mar 22, 2013
306
45
65
Paynes Bay - Barbados
See also several posts on a similar thread "iPhone Overheating"....
Glad you tracked down the issue, as 'warm' is certainly acceptable and normal in many situations. But 'hot' however it is defined , indicates something's amuck somewhere, and can be dangerous in a few cases. I'm also a great '4s' fan :)
