My iPhone will not auto-sync when connected to my computer
SnkerHeAD
Jun 17, 2007
34
Just wanted to know if its me .... or when i dock my iPhone on my G5 And iTunes pop's up nothing happens why is it now Auto Syncing like my ipod did when u dock it..
iJohn
Jun 21, 2007
384
Long Island, NY
johnburke.tumblr.com
A complete sentence would be more helpful but I think you're talking about Auto-Sync and it not working?
MAke sure the option is checked in iTunes otherwise nothing will happen when it is connected to iTunes. If you're having trouble, uncheck AutoSync, Click Apply. Disconnect your iPhone. Reconnect your iPhone, check Autosync and you should be good to go.
dahmer
Apr 10, 2008
Little Rock, AR.
I have a question that hasn't been addressed, either that or I'm searching for the wrong query in the search engine...
Can you stop the sync process after you've connected the iPhone, if iTunes is set for autosync when phone is connected?
rmfnla
Yes; the slide bar that usually says "slide to unlock" will say "slide to cancel," meaning cancel the sync.
You can restart the sync by clicking on the Sync button in iTunes.
nishant_81
Mar 3, 2008
33
and you can also then uncheck the setting in iTunes which says automatically sync iPhone when connected.
dahmer
Apr 10, 2008
Little Rock, AR.
Beautiful, thank you. Not you beautiful, the answer to my question. hardy har...
Also, when I connect and sync, outlook over writes the contacts on my iPhone. Is there an "iPhone wins" box to check or uncheck or some such thing?
nishant_81
Mar 3, 2008
33
Yup. When the iPhone is connected, in iTunes, click the Info tab and scroll down to the bottom to the Advanced header. You should see this setting there. hope that helps.
