My iPhone won't ring
bavman
May 5, 2008
19
When my iPhone is resting or locked and i have an incoming call the phone doesn't ring or vibrate like its supposed to, but if its in the charger or im using it, it does ring when i have an incoming call...any ideas?
chcorey52
Dec 25, 2007
556
try reseting general settings? im pretty sure
bavman
May 5, 2008
19
nope didn't do anything...when i called myself it didn't ring so i unlocked the phones then all my bars went out and it said NO SERVICE and after i hung up all my bars came back and it said i had 1 missed call..i don't nknow why it keeps doing this
chcorey52
Dec 25, 2007
556
wow sounds like its a time for a restore....you should prob set up as new also so you don't have the same prblem again
15,385
1,089
well, you won't be able to receive calls if your iPhone is accessing data through edge.
sounds like that may be the issue.
psylichon
Oct 31, 2007
16,591
751
41
Philly
Good call.
Are you jailbroken? If so, use BossPrefs to turn off the Edge antenna and see if that helps.
15,385
1,089
except I just noticed he said he has this problem when it's locked too.
curious...
psylichon
Oct 31, 2007
16,591
751
41
Philly
When it locks it switches off wifi and goes to edge. If he docks it in the vicinity of wifi, then it will never be on edge when docked and lit up. Could be some sort of rogue app trying to constantly access the internet?
snavemit
Sep 3, 2007
Try ejecting your SIM card and then make sure that it is seated properly. I had a similar issue and this solved the problem.
bavman
May 5, 2008
19
Well i have tmobile and it always displays the EDGE sign, but when i turn it off using bossprefs it still displays it.
