My mail and wireless are working differently?
Chessh2036
Jun 27, 2007
101
with my old iPhone my email would make the noise everytime i got a new email, well now I have to press the refresh before it will say i have new mail before it would check normally, anyway to fix this?
also when i get my phone out of sleep it says connected to 3G but then 10 seconds after i unlock it says its connected to my wireless? is this something i should be worried about?
thanks
iAttorney
Sep 30, 2007
90
Houston, TX
Try setting the iPhone to autocheck, rather than manual. It will be under settings, fetch new data.
As far as wifi turning on 10 seconds or so after awake, it is normal. The wifi antenna turns off by default when iPhone is sleeping to help conserve battery power. No worries and enjoy your new 3G!
Hope it helps.
