My only issue with iOS7 is that it's killed my vehicle connectivity.
jaydoc1
Sep 23, 2007
608
I have had great luck upgrading my 4S to 7. Perfectly smooth transition from Jailbroken iOS 5. I have had zero issues with it and really like it.
Until the last couple days when the wired vehicle connectivity in my '13 Rubicon and my '10 Suburban more or less quit. Bluetooth still works well in the Jeep but USB control of music is non-existent. So I can stream and listen in the Jeep, I just can't plug it into either vehicle and have any music apps work.
Now that I think of it it's since updating to 7.0.2.
Anyone else experiencing this?
5,578
I'm on 7.0.2 and still have USB connectivity with my Sony head unit. Have you tried a hard reset? If that doesn't work, you may have to figure out how to update the firmware for stereos.
jaydoc1
Sep 23, 2007
608
Yep, I did try a hard reset. It may indeed require a firmware update for my stereo. Frustrating as the functionality was so great before.
5,578
That would be frustrating. I've heard of it happening before to others after updating. Good luck with it.
