my phone is unlocked jailbroken, how to select other txt tones?
NickT916
Jan 4, 2008
266
I remember reading a while back that the only way you can have other txt sounds on your iPhone besides the 7 stock ones, is to have your phone jailbroken. well my phone is jailbroken and unlocked, but when i go into sounds it still only gives me 7 stock tones. but i have tons more in my rings section, is there a way to change txt sounds? thx
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
You have to SSH into your phone and modify the SMS tones in the UI sounds area.
You can find the ui sounds at:
system/library/audio/UIsounds
NickT916
Jan 4, 2008
266
im not sure what this SSH means? do i connect phone then go through iTunes or is this through phone or something?
