My replacement iPhone 4 backlight bleed
Appleboy
Jan 24, 2011
151
I was in a dark room, brightness all the way up with the screen all black and I can see light coming from the side.. Damnit anybody else? don't want to go to Apple again
6,683
51
I have a little light bleed on mine. no biggie. If it bothers you that much, the maybe you should go back to Apple. But let me ask you a serious question. How important is it? i mean how often are you going to have the brightness on full and the screen black? If you are watching a mpvie and it messes with the picture, then thats a problem and needs to be addressed. otherwise, you'll probably never notice it. i never notice mine.
6,683
51
Do this. Set the brightness to what you normally run at, load a video or movie that is letterbox, and watch it. If the bleed is distracting, that would be bad, and by distracting, I mean it it so blatantly obvious that your eyes gravitate to it even if it's a really good movie.
Now, load up another movie that is full screen. Does the bleed affect the colors of the video? If so, take it back.
If it's not bad and you're just worried about it getting worse, all I can tell you is that I have had my iPhone for over a year now, and the bleed is the same as the day I got it. I believe I can get worse if you run your brightness high all the time, but even then, I think you won't have the phone long enough to see that happen.
