My Screen Shrunk
Randy Stevens
Jan 12, 2012
I am on an iPhone 4 with 5.0.1 that has been JB for almost a month. Suddenly, tonight my screen has shrunk to the top left corner of the display. I have tried to go into winterboard to respring the phone and cannot get the touch screen to work. The home screen looks as if everything is normal. I have tried a soft reset without avail. Can someone please help me?
Randy Stevens
Jan 12, 2012
If it were only that simple. I am at work and do not have iTunes available. If I do a restore will I lose my jb?
This is caused by the installation of an incompatible app. You'll need to do a hard reset first. Press home and power buttons at the same time. Ignore the slide to power off and let go when you see the Apple logo. Put it in safe mode with SBSettings when it boots and then uninstall the incompatible app.
Yes, you'll lose your jailbreak if you restore, but you'll probably be able to fix this without restoring.
Randy Stevens
Jan 12, 2012
I do not have SBSettings and cannot load it from Cydia because I can't tap the install button. Any other way?
snurblet
Apr 16, 2009
298
WNC, USA
If you can get to the point where you can uninstall Cydia packages, I had the same problem with "LastApp" after updating to 5.0.1.
But I has SBSettings installed so I was able to get into safe mode.
Dj101
Nov 21, 2010
114
Pensacola Fl U.S.A.
www.Mix.dj
it is a know issue with winterboard and or activator
unfortunately,you will need to restore this time
the first thing i recommend after the next jailbreak is to install sbsettings onto the notification pulldown first!
this way you will be able to get into safe mode to fix the issue
