My Silence Switch is Broken, Apps to Fix it?
Jchase
Feb 14, 2009
Topic says it all. My switch will trigger from mute to unmute on the slightest jiggle. Is there a way to soft mod this thing?
Help would be great. Thanks.
Jchase
Feb 14, 2009
Yeah it's a 3G. Is there a number I can call to get that started?
Also, is there a way to back up all the data, not just contacts and stuff, but Cydia and the software from that?
15,385
1,089
Apparently AppBackup backs-up cydia apps and files.
never tried it myself.
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
If you're near an Apple store, you could make an appointment at the Genius Bar and go from there.
seanwes
Feb 13, 2008
1,667
San Antonio, TX
Restore your phone to unjailbreak it. Go to http://www.apple.com/retail/geniusbar/ and set up an appointment with a Genius. Often times, you'll be able to make an appointment same day. They'll take a look at your phone, and likely give you a refurbished replacement. Good luck.
