My usage time is running always?
YAF
Jan 17, 2008
I just noticed my usage time is running constantly!
My Wi-Fi is off
I check for emails every hour automatically.
What could make the usage time run authomatically? It just started doing so..., it did not before?
Please advice?
YAF
Jan 17, 2008
Bumping this post!
Does anyone know why usage is running all the time?
Its draining out my battery..., please advice?
jpm
Aug 5, 2007
212
Use either Yahoo or Gmail push and then you don't have to have it autocheck your email at all.
jpm
Aug 5, 2007
212
Yahoo and G mail have "Push mail" It means whenever you get an email at your account the service "pushes" it right to your iPhone and the iPhone makes the little sound and notifies you. You can keep the auto check set to manual and still be notified right away when you get a new email.
It works the way push mail works on a Blackberry.
slipperypete
May 20, 2007
205
I have a GMAIL account and i need to manually check to get my e-mails....no "push"
Marianne
2,326
Massachusetts
marianneschultz.com
usage time doesn't have anything to do with how often your phone is set to check email. straight from the iPhone's user guide in the section on Usage Statistics:
- Amount of time iPhone has been unlocked and in use since the last full charge
- Amount of time iPhone has been in standby mode—locked but turned on—since
the Call Time and EDGE Network Data statistics are self-explanatory, of course...
AWY
Sep 6, 2007
110
California
My Wi-Fi is off
Please advice?
Is your iPhone on "Auto-Lock? If not, you night consider doing so. There are 5 available time settings to choose from. Hopefully, this should help limit some of your usage time and preserve your battery, as well.
slipperypete
May 20, 2007
205
Then you need to go to Google and read up on how to set it up for IMAP which will do push. When you add it to your iPhone you don't select GMail you select Other. Read on ...
Had it set up for IMAP, no push....
