Mystery, info needed.
JFN
Jul 12, 2008
273
14
Nor Cal
Ibelieve pocket informant is causing the error in the screen shot, but I don't understand why? Any ideas?
6,683
51
Well, I think you are dead on with thinking its informant (since the error is titled "Informant") but as to the why... It depends on what the app does. Check to see if you have any other applications open that might be putting a strain on Informant.
JFN
Jul 12, 2008
273
14
Nor Cal
Thanks Hawk, I'll look with that said I have informant set to sync on launch only. The other day it kept firing this message about every 30 seconds while on my way to Sacramento I had to park and delete the app and noticed the phone was way hot, after deletion everything was normal, guess I better email the Dev.
applejosh
Oct 15, 2009
100
Did you have ToodleDo configured? I think PI utilizes ToodleDo APIs, so that kind of makes sense to me. I think the calendars are the local ones (or can be). (Still good idea to report to the dev.)
