n00b 3.0 help!
Aug 1, 2007
1,232
44
i wanna upgrade to the 3.0 beta 5. is there maybe a cracked version or something thats modded so i can use youtube on this? also would like mms possibly working? thanks so much.
iphun
Mar 16, 2009
1,967
PA
YouTube is working so I don't know what you mean by that? And it seems that as long as you have the ipcc installed to your phone from - http://www.megaupload.com/?d=J84S5YPV using the first iTunes 8.2 pre-release to install the ipcc. As soon as you are on the newest iTunes and beta 5 you can't add the ipcc to keep mms.
Aug 1, 2007
1,232
44
YouTube is working so I don't know what you mean by that? And it seems that as long as you have the ipcc installed to your phone from - using the first iTunes 8.2 pre-release to install the ipcc. As soon as you are on the newest iTunes and beta 5 you can't add the ipcc to keep mms.
Hey man. I PM'ed you =)
