Native app removal
fjclaus
Dec 8, 2009
105
I have native apps such as compass, voice memo, stocks and other. I never use them but I cant delete them. Is there a way to get rid of them?
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Unfortunately no, if you're jailbroken you can hide them, And I've heard of people even being able to delete them which I don't think it's safe anyway. That's about it.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
I was hiking. Lost the sun. Was a new trail. Had a map and gps but need a direction so out came the iPhone compass. Poof worked like a charm.
Now if only it doubled as a moral compass.
fjclaus
Dec 8, 2009
105
No u can't delete them. Sorry.
I have all of those I don't use in a folder. Labeled crap lol
Not a bad idea. The apps are still there, but at least they are only taking up one space instead of 6. Thanks for the folder idea Rugaby.
Alan J
Aug 14, 2011
You can delete native apps only if your device is jailbroken, using a program such iPhone explorer.
You basically drag the relevant folder out on to your desktop. But please be warned some of these native apps are connected to other functions on your IDevice. The last time I used such a programme was to unjailbrake a 3GS, I deleted the cydia folder and rebooted one unjailbroken phone. Personally now I would just do as advised here and stuff any unwanted apps in a folder
When you update/restore your IDevice they will reappear anyway.
