need a case for my duty belt.
matt33263
Jun 9, 2008
87
Texas
To all the Police officers, secuirty officers, who ever else uses duty belts. I need a case/ holster to put on my belt. It needs to be black and my belt is a 2 inch leather one. I want something that is not easy to fall off my belt or easy for the phone to fall out of case.
Thanks.
Geo
Mar 9, 2008
108
There is a phone case in leather at the everythingicafe store: http://store.everythingicafe.com/griffin-elan-holster/4A24A2609.htm
Some LEOs mention the problems with tussles and they keep the phone in their pockets. In that case the everythingicafe has some 'Pocket Pouches' to choose from: http://store.everythingicafe.com/iphone-pocket-pouches.htm
While not quite 2 inch in the clip, it may suffice for you.
http://forums.everythingicafe.com/threads/iphone-3g-cases-customer-review-section.28565/
http://www.911gear.ca/product_info.php?products_id=1358
Try this. Not Leather, but nylon and should work. http://www.maxpedition.com/store/pc/viewPrd.asp?idproduct=441
Also: http://www.galls.com/style.html?assort=general_catalog&style=TE612
Try this cop site: http://www.copsplus.com/prodnum4033.php
There is also the possibility of using a 'pager case' which might fit the iPhone.
Hope this helps.
and remember....'be careful out there!'
matt33263
Jun 9, 2008
87
Texas
Hope this helps.
Thank you I will check them out and see if I cant find one for my phone. Thanks again.
Update: After looking at them I have decided on going with the one from galls I had seen that one before and after looking at all the ones you suggested I ordered the galls one. The pocket pouch would be nice too but I keep my phone in my chest pockets right now so no big deal with scratching the phone since I don't have any sharp things in that pocket
