Need a thin case
icecreamman2
Jul 23, 2008
207
san francisco/vancouver
ok i need a case but i hate all the bulkyness of all the cases. iv tried the incase slider, the rubber incase one. everything they are all to big. they feel huge in my hand. anything a little thinner?
glsda
Oct 17, 2007
1,440
50
California
An imaginary case?
kenneth
Aug 19, 2008
1,465
Texas
Your probably not going to find a case that is thinner than the Incase slider... just go with an invisible shield.
dcom
Aug 7, 2007
1,421
Suwanee, GA
If you have the $, try the Vaja iVolution Top case. It's pretty thin, protects the screen, and feels comfortable, at least to me. Plus it's not rubber so it slides into your pocket easily
DUKEL
Jun 27, 2007
646
S.D. CA 92109
The seidio innocase II is thinner than the incase slider with almost the exact same form factor. Still the invisible shield is really the only way to go to keep the iPhones slim profile, it's what I'm using right now.
iLiam
Dec 18, 2008
53
Chesterfield
Go on www.youtube.com and type in itsmemorphious and he does loads of reviews on case he has like 18,000 subscribers - check his reviews and unboxings out!
cevtv
Nov 23, 2008
51
It gets no thinner than this, as far as cases go. Looks good, but it is a cheap piece of plastic that you are going to have to pucker up and get riped off for $34.00. Don't feel bad, many of us own this case.
I LOVE the Air Jacket!
Marcos
Dec 19, 2007
140
Phoenix, AZ
The airjacket finish falls off after a while. Ive used 4 cases so far and the best one so far is the Incipio Feather. Thinnest case out there with no bulk.
Dustu2
Jul 16, 2008
478
Houston, TX
Umm...What finish? It's clear.....
That's the point! :p
But on a serious note... OP, how can you not like the Incase Slider? It has just enough body to it to provide moderate shock protection, and it's still really thin and form-fitting.
iPhoneMonster
Jan 18, 2009
461
It's exactly what I was going to suggest. But maybe, you might not want to get the front. I bought the whole set and wasn't too happy with the front. I bought a Marware SportGrip and it came with a static cling, with them you actually forget it's there. With the invisibleSHIELD front face it's a constant annoying thing. Maybe it was a bad batch or something but my back install is perfect my front was really annoying.
