Need for speed shift missing
damnskippy
Jun 11, 2010
44
Went to play Need for speed shift on my iPad and it did nothing but crash. Went to look in iTunes to see if others had issues and it is not there. Thought that was interesting. Anyone else?
You just need to delete it and reinstall it. You won't be charged again.
damnskippy
Jun 11, 2010
44
Thanks, yeah I know but I don't know if it has a backup of my place, cars etc. Plus I have a feeling they will be releasing an update soon since it is gone from the app store.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Your best bet is to wait for the update, since it's a known issue and it's been removed from the app store, they will fix it. If you uninstall it and reinstall the app you might encounter the same problem again.
