Need help adding ringtones, logos, icons to iPhone
Jul 3, 2007
OK, I have never modded or hacked anything in my life because of the fear of bricking it. So, I have a few questions before I try it.
1.) Do you think it will be easy for me if I'm not good with these things. I got up to the part where jailbreak performs stuff on your iPhone, but didn't do it because of fear lol.
2.) Is adding ringtones and icons and sounds to the iPhone hard, what do you have to do. Also, somebody said before they had Mario say "bahbye" when they locked the phone. How would you go upon doing that.
3.) Where can I find things like icons, ringtones, sounds, carrier logos, battery color, carbon fibers sliders? And how would I put it in the iPhone?
Thanks for your time and any help would be greatly appreciated!
Jul 17, 2007
Honestly it is very easy. Its basically replacing files and there is a drag and drop program now. Everything is just sound and pictures so if you can make small PNG's then you can mod icons, sliders, etc. Just try it, I was as scared as you were, but it actually is easier to mod than normal Ipods =P
