Need help choosing external battery
dennisd
Nov 23, 2008
29
I'm looking to buy an external battery, but my choices are 1900 mah or 1000 mah. Does anyone know what mah the phone requires or does it not make a difference.
Thanks,
dd
JWiPhone
Sep 18, 2007
6,357
447
Los Angeles, CA
Thanks,
dd
It doesn't make any difference but I would go with the higher mAh. It will give more charge life to your iPhone. In other words, you will get more charges to your iPhone from the external battery before the external battery runs down. I think the mAh of the iPhone internal battery is 1200 mAh so if you get the 1000 mAh it will not fully charge the iPhone battery. Here is another one I just learned about. It is 5000 mAh. The 1900 mAh is a good enough external battery for the iPhone though.
http://www.imaxpower.com/
