need help connecting to wi fi
iacobone
Jul 30, 2008
hey, i cant connect to my wi fi it says i need a password and ive entered my WEP key many times its a 27 digit code and it doesn't work. i was wondering what would i need to enter as a password to connect to my internet
In the WiFi settings, tap the blue arrow next to the network you want to join. Then, scroll to the bottom and tap "Forget this network." Then try again.
iacobone
Jul 30, 2008
just tried that and it still doesn't connect
fsas06
Oct 15, 2007
604
Las Vegas
my wep key is 26 letters/numbers long...maybe look in your router settings and make sure u have the right key ?
iacobone
Jul 30, 2008
yes i recounted and its a 26 digit code and ive entered it 10 + times and it doenst work, is there nething besides a wep key that would work or could my router be blocking access?
theevilone
Dec 30, 2007
85
put in the password or just disable security while useing wifi then turn it back on when finished.
iTrey.Bates
Jul 9, 2008
106
Texas
disabling worked for me..tell me what happens when u try it
aaronsiphone
Dec 28, 2007
297
I had a simular problem, Two things I did and both worked, firsty make sure all capital letters are in capital and also check your Wi-Fi doesn't have a pairing button as you have to press this when setting up and new connectiong
Hockey Puck
Jan 22, 2008
41
PHOENIX ARIZONA
wi fi connection problems
Do you have a router hooked up via earthernet cable directley to your computer in your home. Typically if you have high speed internet for example? That 27 digit WEP key with letters and numbers is not the password.
Mech
Jul 15, 2008
Which key are you putting in? Don't they give you 4 generated ones? Be sure you are just doing the top one. My WEP works fine on my iPhone.
HBOC
Aug 4, 2008
108
Portland, Oregon
i installed and setup winscp (winscope) sync up my iPhone to PC. works flawlessy. I don't know if that was necessary, but at least i learned something new.
