Need Help Deleting Photo Albums on iPad
Retusnavy
Sep 13, 2011
Before I upgraded to ios5, I had two photo albums, "Camera Roll" and "Photo Library" and after then update I have a new one called "Pictures" which is an exact duplicate of "Photo Library". I can't delete the album or the pictures in it, any ideas. Also when I transfer pics from "Camera Roll" to any of the other albums and then try to delete the pics out of "Camera Roll" it make me delete both copies of the pics. I would appreciate any help here.
Sent from Jim's iPad2
Retusnavy
Sep 13, 2011
Thanks for the info, I looked but don't see the option to do that.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
In iTunes under the photo tab you will see what folders it is syncing to and from. If you uncheck the folder you no longer want on their and hit sync or apply on bottom right it will only leave the folder that you left checked. Further more if you want to create a new folder in your photo program on your computer and add photos to it you can then sync that folder to your phone or iPad.
Mendo88
Dec 8, 2010
I have a folder called iPhone that I sync from. Since iOS 5 I know have 2 copies of that album, one called iPhone and one called photo album. If I untick it then sync it removes all of them. I cannot seem to remove one of the albums.
