MacBook need help fixing a MacBook
dcjose20
Aug 6, 2009
62
Corona, CA
So I will given a macbook which appears to be a 2006 or late 2006 white macbook. I bought a charger for it and tried to power it up but not surprisingly it did not. The little light on the charger by the pin dock was orange so I do think it was possible charging it. Where would be a good place to start to try and narrow down what could be wrong with it? Thanks in advance for your help.
Jennifer Chesney
Mar 28, 2013
27
Hey there! I am new to everythingicafe so I'm just seeing this post. If you flip the laptop over there are about 4 or 5 clear dots, when your laptop is fully charged they will all be green. If its not charging I assume you would need a new battery. Take it to the Apple store or just order a new battery online.
