Need Help Font App
kariya9mdoa
Oct 26, 2007
80
Can someone give me the source for the font app in installer cause i havnt got it.
I did have it a while ago and then the phone stuffed up now i am on 114 and i havnt got it.
Thankyou in advance
HappyModding
lman
Oct 18, 2007
632
Thankyou in advance
HappyModding
Yeah i had it and now i cannot seem to find it either
lman
Oct 18, 2007
632
well when i went to 1.1.4 i installed it then i had to restore and i haven't been able to find it again. any chance you could upload it to mediafire or rapidshare so i could download the app.
An just make a note of where you place it in the folders of the HD so i can make sure i put it in the right place?
if thats not asking too much
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
If you have the sources, SSH to / >Applications, and add it (FontSwap.app). The fonts themselves are found in / >System Library> Fonts; you can actually add more fonts than what FontSwap.app actually provides.
I hope that helps.
lman
Oct 18, 2007
632
I hope that helps.
If i add fontswap.app to the applications, will i have to enter in the fonts or when i open it it will do it?
if i have to manually do it, i'd need to know the names of the fonts...
lman
Oct 18, 2007
632
I added FontSwap.app to my applications and nothing happened...i'm not sure what i'm exactly supposed to do. After i add it through SSH, its just an empty folder in my applications folder.
lman
Oct 18, 2007
632
BTW, the sources should show up as "iPod Touch Fans" in your source list.
yep I have it in my sources. When I manually added fontswap to the applications folder I just got a blank fontswap folder. Do you think you can just go on your ssh extract the applications folder for it or whatever you'd need. Zip it up and upload it to rapidshare or something? Unless you know why I have a blank fontswap folder...
lman
Oct 18, 2007
632
Man, you really want this thing bad. It is pretty cool. I don't know anything about "rapidshare", but tell me more and I will try to get it to you.
Later
Haha, well i wouldn't be this persistent if didn't know for sure it works on 1.1.4. I liked it a lot when i had it, it was that one more thing that i could customize that made it unique...Rapidshare is just a site you can upload a file so i can download it. You can use any site you want but rapidshare.de is the one of the top of my head to use. You just upload the file you want and then when its done you copy and paste the link to where it can downloaded. Thanks man.
lman
Oct 18, 2007
632
Anyway, i found it online and downloaded it and its on my phone. However, when i make changes and respring the changes don't stick so any chance you know why? Permissions?
