Need help moddig please
Maaz
Jun 30, 2007
584
LA California
hey guys i have some icons and stuff downloaded, but how do i change the icons, and sms bubbles and battery logo and stuff.
Maaz
Jun 30, 2007
584
LA California
k for battery logo i copied all batt.pgns 1-17 and then i removed it from the folder i get when i run ibrickr, and now the battery logo works, so i don't know exactly how i did it,and i still don't know how to do custom icons.
Ace4261991
Jun 18, 2007
530
i brickr good i can help you now
ok heres the most important list you need as reference to do all your modding
ill explain everything at the bottem
im not a pro at this yet i just started a couple days ago but i do know how to do icons and other basic stuff/
Homescreen
Calculator Icon
/Applications/Calculator.app/icon.png
Maps Icon
/Applications/Maps.app/icon.png
Calendar Icon
/Applications/MobileCal.app/icon.png
Mail Icon
/Applications/MobileMail.app/icon.png
iPod Icon
/Applications/MobileMusicPlayer.app/icon.png
Notes Icon
/Applications/MobileNotes.app/icon.png
Phone Icon
/Applications/MobilePhone.app/icon.png
SMS Icon
/Applications/MobileSMS.app/icon.png
Safari Icon
/Applications/MobileSafari.app/icon.png
Camera Icon
/Applications/MobileSlideShow.app/icon-Camera.png
Photos Icon
/Applications/MobileSlideShow.app/icon-Photos.png
Clock Icon
/Applications/MobileTimer.app/icon.png
Settings Icon
/Applications/Preferences.app/icon.png
Stocks Icon
/Applications/Stocks.app/icon.png
Weather Icon
/Applications/Weather.app/icon.png
YouTube Icon
/Applications/YouTube.app/icon.png
The Dock
/System/Library/CoreServices/SpringBoard.app/SBDockBG2.png
[edit]
Locked Screen
Unlock Text
/System/Library/Frameworks/TelephonyUI.framework/bottombarlocktextmask.png
[edit]
Global
Color or picture of ringer background when you used volume keys
/System/Library/CoreServices/SpringBoard.app/hud.png
Alert bubble for calls, sms, etc.
/System/Library/CoreServices/SpringBoard.app/SBBadgeBG.png
"Top Background where the signal bar is"
/System/Library/CoreServices/SpringBoard.app/FST_BG.png
[edit]
Battery Charging Screen
Battery Backround
/System/Library/CoreServices/SpringBoard.app/BatteryBG_1.png-BatteryBG_17.png
[edit]
Locked Screen
Slider Bar
System/Library/Frameworks/TelephonyUI.framework/bottombarknobgray.png
[edit]
Top Info Bar (signal strength, battery, etc.)
Carrier Logo
/System/Library/CoreServices/SpringBoard.app/FSO_CARRIER_ATT.png (lighter one)
/System/Library/CoreServices/SpringBoard.app/Default_CARRIER_ATT.png (darker one)
Signal Strength
/System/Library/CoreServices/SpringBoard.app/FSO_0_Bars.png-FSO_5_Bars.png
/System/Library/CoreServices/SpringBoard.app/Default_0_Bars.png-Default_5_Bars.png
Bluetooth
/System/Library/CoreServices/SpringBoard.app/FSO_Bluetooth.png
Background (bar color) HomeScreen
/System/Library/CoreServices/SpringBoard.app/FSO_BG.png
Background (bar color) Lock mode
Background (bar color) All other screens (Text, Safari, Mail, etc.)
/System/Library/CoreServices/SpringBoard.app/default_BG.png
WiFi Bars
/System/Library/CoreServices/SpringBoard.app/FSO_0_AirPort.png
/System/Library/CoreServices/SpringBoard.app/FSO_1_AirPort.png
/System/Library/CoreServices/SpringBoard.app/FSO_2_AirPort.png
/System/Library/CoreServices/SpringBoard.app/FSO_3_AirPort.png
/System/Library/CoreServices/SpringBoard.app/Default_0_AirPort.png
/System/Library/CoreServices/SpringBoard.app/Default_1_AirPort.png
/System/Library/CoreServices/SpringBoard.app/Default_2_AirPort.png
/System/Library/CoreServices/SpringBoard.app/Default_3_AirPort.png
[edit]
Power on Screen
The logo (only shows when it starts to minimize)
/System/Library/CoreServices/SpringBoard.app/Applelogo.png
[edit]
Power Off Screen
Power off slider
System/Library/Frameworks/TelephonyUI.framework/bottombarknobred.png
[edit]
Calculator
Background
/Applications/Calculator.app/CalculatorBackground.png
Screen Background
/Applications/Calculator.app/LCDBackground.png
[edit]
iPod
Rating Stars
/Applications/MobileMusicPlayer.app/star_filled.png
[edit]
Phone
Keypad
/Applications/MobilePhone.app/BarDialer_Sel.png
[edit]
SMS
Input Field (Bubble where you type you're text message)
/Applications/MobileSMS.app/BalloonInputField.png
Baloon 1 (Bubble where sent text messages are)
/Applications/Calculator.app/Baloon_1.png
Baloon 2 (Bubble where received text messages are)
/Applications/Calculator.app/Baloon_2.png
Bottom Bar Background (Background behing the text input field) /Applications/MobileSMS.app/MessageEntryBG.png
[edit]
Safari
Url Bar
Idle
/Applications/MobileSafari.app/Url.png
Inactive
/Applications/MobileSafari.app/UrlInactive.png
Active
/Applications/MobileSafari.app/UrlProgress.png
[edit]
Mail
Trashcan for deleting mail /System/Library/PreferenceBundles/MobileMailSettings/trashmbox.png
ok so first you look at what you want to change for example you said icons so say you want to change the ipod icon then you go to the list i posted and look for ipod icon and bam
iPod Icon
now go to ibricker and were it has the 4 links next to the sample iPhone click the last one i believe that says files
now on the sample iPhone itll show some links like applications, system, ect. then you just click the one that the list told you to go so for ipod icon the first directory says applications so you click that. then another list will come up and then you look for the next directory it says in the list which is mobilemusicplayer.app so then you get your downloaded icon for the ipod icon and you press browse and you find it and then press upload but you have to make sure its named what the list tells you for this example it says icon.png so just name it icon and it will replace the old icon with the new one. thats basicly what you do for everything else you want to change. if you need any more help then say so and ill help asap
Ace4261991
Jun 18, 2007
530
yeah I do its the same as my user name here but I won't be on till this evening because I have to go to work
