need help on customize
lowram00
Feb 11, 2008
468
memphis TN
i have a 1.1.3 16gb iPhone and when i go change the springborad strings what i put never stay i put say hello tom and then i exit it out of it it still say slide to unlock
dito
Sep 28, 2007
79
i get same thing. i hate default sounds. i need my video game sounds back... so far i hate 1.1.3 except for being able to create my own ringtones on iTunes 7.6 (no more sendsong, that you have to reset everytime you sync)
dito
Sep 28, 2007
79
figured it out.. thanks to mjk2. install customize, restart, install bsd subsysten, restart, install customize (modded version) , restart. THEN it worked for me...
amgsl55
Feb 18, 2008
I'm having trouble with customize also. I have BSD installed and the modded customize, however when I try to hid icons it never works.....any ideas?
cypher7810
Sep 12, 2007
74
I am having an issue with my Customize just not showing up. I have the 1.21 customize and the BSD installed but when I launch Customize it just sits with the spicychicken logo on the screen and then goes back to the dashboard.
cpolaris502
Nov 15, 2007
132
Rogers, MN
you have to have the modded version for it to work on 1.1.3. first uninstall the normal one and then go into installer and then add the source http://www.touchrepo.com/repo.xml
to add the source, click on the souces button at the bottom left of installer. then "edit" at the top right and then "add" on the top let. then type in the source url
then in the utilities category install customize 1.21(custom)2
cypher7810
Sep 12, 2007
74
Ahh thanks , I didn't know how to add it.:laugh2:
