need help someone
lowram00
Feb 11, 2008
468
memphis TN
anyone got 1.1.4 and jailbreaked it and get customiz3 to work and summerboard to work if so please share
lowram00
Feb 11, 2008
468
memphis TN
like on summerboard the dock change but not the icons and customize i try change where say slide to unlock and it wont change
15,385
1,089
i don't use customize anymore, but summerboard is working perfectly for me.
15,385
1,089
i installed it :)
nothing special, honest.
make sure the "Theme Icons" switch is on in SMB Prefs, and if you installed the themes yourself, make sure the directory structure and nomenclature of the icons are correct.
15,385
1,089
did you get the themes from installer?
have you tried restarting your phone?
15,385
1,089
ever since 1.1.3 i have had to move the themes to the directory var/mobile/summerboard/themes directory. I think that's the correct path... i may be missing a level or two. sumerboard puts them n a place by default that it can't use them any more. i don't know why they haven't fixed this yet.
i'll try to write up a more complete explanation when i get home.
