Need help transferring contacts from iPhone 3GS to iPhone 4S
Turtow
Oct 23, 2011
I am getting ready to sell my iPhone 3GS and get a new iPhone 4S. Can someone walk me through how I go about transferring all my data from my old to new iPhone? Thanks much!
M
E Pow
Dec 16, 2008
109
11
Cincinnati, OH
If you have computer access it's easy. Just sync and back up all your data and personal info through iTunes. Then set your old phone back to its factory settings, this will erase everything and your phone except for the stock apps. It will be just like when you 1st bought it. Also, if you have AT&T make sure you remove your SIM card. That's pretty much the basics.
Sent from my iPad using iCafe app
rambo47
Apr 4, 2010
528
79
Northern NJ
I wouldn't erase the old phone until the new one has everything on it just the way it's supposed to. But like E Pow says, just back up the old one to iTunes and then restore the new one from iTunes.
