Need help uninstalling an app
Apr 12, 2008
21
Houston, Tx
I downloaded P-officeviewer from the iPhone cake source. while downloading it gave me an " Error: Main script execution failed " sign. The icon showed up on my homescreen then I tried to uninstall it through Installer but it's not showing up.
guest0320
Nov 11, 2007
728
Chill bro!
It's kind of complicated to explain but easy to do.
Do a search for winscp and ssh here on the boards and you will figure out how to do it.
Sorry for the lack of help, but it would be a big pain to have to type it all out.
Also you can use an app called Mobile Finder and go into your phone WITH your phone and examine where it is and delete it that way.
I would recommend Mobile Finder which is in installer. Look under all packages.
Good Day
Dana
