Need Help Unlocking iPhone
Sep 17, 2009
Hello. I just got an iPhone but it only works for AT&T right now so I need to unlock it.
I upgraded to 3.1 already. I looked up how to unlock it myself which was:
1)download iPhone1,2_3.1_7C144_Custom_Restore.ipsw
2)hold shift and press 'Restore'
3)select the custom firmware and install
This is where I have problems. It takes like ten minutes and then all of a sudden I get a message that says unknown error 1601 or 1604 or something.
Then I press OK and it goes into recovery/dfu mode.
Can somebody please help me and tell me why it's doing this and if I'm doing it wrong? I really wanna use my phone with T-mobile..
Thanks,
Caden Grant
one_crazy_dude
Sep 13, 2009
460
72
Toms River New Jersey
Thanks,
Caden Grant
sorry to here you already up dated to 3.1 first. when you did the update from Apple it changed your base band and now you can not un lock only jailbreak
have a read http://blog.iphone-dev.org/
RossMc
Jun 28, 2009
1,124
Newcastle, UK
Yeah as said you can't unlock now and mabey never be able to unlock unless the Dev-Team find a exploit for 3.1 with the baseband already updated or in a future firmware release they find one.
one_crazy_dude
Sep 13, 2009
460
72
how ever if you are having problems just jailbreaking i found this. maybe it will help.this was taken from another forum and dot from me
Just managed to do it….secret id if you upgraded to 3.1 it wont work..you must downgrade back to 3.0 (which is the tricky part), follow http://www.redmondpie.com/downgrade-iphone-3.1-to-3.0.1/
Jail break using redsn0w..then proceed as above..ive done mine and 2 friends phones ..no problems..
Its a bit tricky , but i’m no IT wizard, just read the instructions and go for it….
Peter McG
Marianne
2,326
29
Massachusetts
marianneschultz.com
Depends on which iPhone he has and if he has a PC or Mac. If this is a V1 iPhone and he has a Mac, he can unlock 3.1 with the latest Pwnage tool. It worked flawlessly for my spare V1 iPhone.
EDIT: Apple has a support article on the 1604 error here. At the very least, reboot your computer and check out the section on USB devices.
one_crazy_dude
Sep 13, 2009
460
72
I think there is a bit of confusion.
To unlock is to be able to use any sim from other carriers like t mobile in an AT&T iPhone and to jail break so the phone can accept 3rd party theams and apps. Now if he updated his phone with 3.1 using iTunes and not a jail broken ipsw like he says he did than his base ban has been changed and Cannott go back to older base ban but can go back to older ipsw. If he wants to use another sim from another carrier ultra snow won't work on the new base band.
In the dev team blog(these r the guys who make the software to jailbreak our phones) I posted eairler if read explains the differences between os and baseband.
RossMc
Jun 28, 2009
1,124
Newcastle, UK
The update doesn't affect V1 iPhones though as the baseband will get unlocked using pwnage tool 3.1
Marianne
2,326
29
Massachusetts
marianneschultz.com
Like I said, it depends on which iPhone he has. From the Dev Team blog:
If you have an original iPhone (1st generation) then 3.1 unlock works with this PwnageTool release.
So, if he has a first-generation iPhone, he CAN unlock 3.1 with the latest Pwnage tool.
