Need help upgrading jailbroken iPhone from 1.1.4 to 2.2
sammies3
Jul 16, 2008
Hello again, I seem to be going round in circles trying to find how I upgrade my jailbroken iPhone, I would like to upgrade to either version 2 or the new 2.2 but after my big problems last time I really could do with a step by step guide, can someone point me to the correct topic etc.
I have 1.1.4 on my phone at the mo.
Thanks in advance
ess_bee
Dec 16, 2008
152
UK
an uprgrade is simple but 1.1.4 to 2.2 is a big upgrade!
SYNC before you update, very important!
simply conntected your iPhone to your iPhone usb cable, plug that into your pc/laptop
Open up iTunes, wait for iTunes to recongnise your iPhone. Once found, click on update ( I think its called, its the button above restore). The upgrade willl probably take about 15 minutes.
Once the update is completed, you will need to re-jailbreak your iPhone...
