NEED Help. What Ap is it...........
Chris.Carter770
Dec 25, 2007
99
What up guys. Hey what's the app where you put your finger on the bottom right side of the screen (where the little light is) and when you rub over it, it pulls up applications on your iPhone that you can scroll thought and when you take your finger off of the screen it goes away.
Do I get that through the installer?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Here you go:
Install a program called "Dock". It will put a small sunburst in the lower right of your screen. You can then put your finger on the sunburst and an arc of icons will open allowing you to launch your programs. Use that to launch Installer and then you can get in and uninstall them. Although installing Summerboard should have gave you the ability to scroll your icons. Have you tried to swipe your finger from the bottom of the homepage to the top and see if the icons scroll so you can get to the others?
