Need help with homescreen
Saurabh
Sep 5, 2007
152
VA
Well i was messing aroud with launcher and rstb, and i accendent made my rstb and launher hidden so i cant acsess them to change what i see and look at someoff my apps. I installd rstb from installer. App so i cant uninstall it beause that is also hidden. I really don't want to restore so what can i do. I have ibrickr so i need some assistance :)
spampy22
Jun 8, 2007
165
46
Columbus, Ohio
summerboard
install sumerboard. Then use the little sun at the bottom right of of the iPhone. It should allow you to access all apps hidden or not.
enigmanic
Jun 27, 2007
513
Actually, it's not Summerboard that has the sunburt, it's "Dock".
Alternatively, you can install MobileFinder and you'll be able to access all your applications.
Saurabh
Sep 5, 2007
152
VA
Thanks a lot guys, havnt tried it yet but when i get come i will, thanks
