Need Help with iPod touch!
pagofreak
Feb 5, 2008
hey guys...i was able to jailbreak my ipod touch to version 1.1.1, but whenever i try to upgrade to 1.1.2 it doesn't work...my iTunes is version 7.4, i downloaded oktoprep, i have the proper files ( 1.1.2 jailbreak and the 1.1.2 firmware ).
PART THAT DOESN"T WORK - i cant seem to start the windows.bat file that comes with the jailbreak...everytime i start the .bat it closes on me right away and doesn't upgrade my 1.1.2 firmware to 1.1.2 jailbroken... i've redone the entire process about 4 times alrdy. Pls help.
enigmanic
Jun 27, 2007
513
i downloaded the latest java but nothing happened =(
After you install java, you need to run windows.bat again. If your screen STILL flashes and closes, that means you're trying to run windows.bat from inside the zip file, which is not correct. Extract the contents of the zip file on to your desktop, then click on windows.bat.
