Need help with SIM card not supported error message
blumoon722
Aug 1, 2009
I downloaded the new software fix (8/1/09) on a jailbroken 2G iPhone. At end of download got "SIM card not supported". Phone goes to dial emergency #, and nothing else.
What can I do?
Try to rejailbreak it?
I have T-Mobile.
Phone was working fine before download attempt.
My daughter said I should not have tried to download on a jailbroken phone.
Any suggestions?
fury
Oct 23, 2007
2,274
238
33
Louisville, KY
Is T-Mobile the official carrier in the country you're in, or did you jailbreak it to unlock it? If so, doing software updates screws that up.
blumoon722
Aug 1, 2009
T-Mobile is my carrier in the US.
The phone was unlocked.
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
You'll need to re-jailbreak using redsn0w, but choose the 3.0 ipsw file when asked to. Then you should be able to unlock with ultrasn0w.
blumoon722
Aug 1, 2009
Thanks for your help.
My buddy fixed the phone , but used version 3.0.1.
Need to get back to 3.0.
How do I do it?
28,365
5,507
You'll want to stay on the 3.0.1 FW, not revert back to 3.0. 3.0 has a SMS vulnerability. You did the right thing by updating. You use the 3.0 IPSW, but you stay on FW 3.0.1 (this works because there is very little difference between 3.0 and 3.0.1). I listed all the steps here.
