Need HELP!
Goallie11
43
So I decided to update from 1.2 to 1.4 today. my phone was already jailbroken on 1.2 and I thought I could just click update in iTunes and start fresh. I clicked it and it updated and said when the iPhone restarts it will reappear in the menu but it hasn't appeared. The phone is sitting on the slide for emergency screen. What should I do?
S
Starry
Guest
Pray...
I'm kidding... :) Search the forum topics there are tons of replies for you.. :)
Or check for posts from OJSAKILLA or TINMAN, iPhoneTONY, JOHN, KNK they are great with this stuff.. :)
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
unplug phone replug back in. Restart iTunes. Reboot pc any of these or all these might be necessary
-howdy Starry
OJsakila
Jul 15, 2007
3,021
go to ..http://www.modmyi.com/forums/downloads.php?do=cat&id=6 and down load the appropiate firmwares you need. Now when you go to restore, hold the shift key down as you press the restore button and iTunes will let you navigate to wherever you downloaded the firmware. Work from there and go from 1.2 to 1.3 to 1.4 to jailbrake....... at least i did...... this would be the safer route
Goallie11
43
Wow thanks for all the replys so quickly. Fortunately all I had to do was restart my computer, i was just a bit worried if it didn't recognize it when I restarted. Now for ziPhone!
If a mod is around you can delete this thread.
