Need some advanced help
Spikefood
Oct 3, 2007
368
Look at this picture. I can't seem to get my iPhone to sync its photos to my PC (they may be getting uploaded somewhere, but I don't know where).
Any ideas?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Right-click on that Apple iPhone device item with the exclamation mark and choose to uninstall it - restart Windows, plug back in the iPhone and see if it rediscovers it ...
Spikefood
Oct 3, 2007
368
Seemed to be working until this happened:
JoeT
Dec 18, 2007
911
Tampa, FL
I'd do what Patrick said. If that doesn't help, uninstall iTunes and the iPhone (as per Patrick's instructions), reboot, reinstall iTunes, and then connect the iPhone again.
Spikefood
Oct 3, 2007
368
Tried all of that but it didn't help. And also it is still a stock phone, nothing modified.
chrismmm
Dec 27, 2007
612
Gwinnett, Georgia
looks like a windows pc. open task manager, look in services or processes to see if it auto start, manual, or something else
Tinman
4,334
183
Aridzona
What version of Windows?
BTW: iTunes has nothing to do with the issue. The iPhone exposes itself as a digital camera via USB. You should be able to plug into any Windows/Mac computer and have it work, no iTunes required. It should even work under Linux.
I would first try the iPhone on another PC/Mac (again, no iTunes required) just to rule out an iPhone issue. If it fails on another PC, reboot the iPhone (turn off, then back on). If it still doesn't work restore it and try again (assuming you have narrowed it down to an iPhone issue).
Mike
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Are you plugging your phone into a non-powered USB Hub? You might try moving it to a different USB port on the actual computer not through a Hub and see if that helps.
Spikefood
Oct 3, 2007
368
Mike
I'll try this on my room mates mac once he wakes up. Hopefully it will work, I don't want to have to restore. =/
Spikefood
Oct 3, 2007
368
Did a soft restore but that didn't help. Ill try connecting it to another computer soon.
