Need some help or advice !
Krystian_E46
Dec 2, 2008
44
Chi-Town, IL
www.e46fanatics.com
Hey guys i have a friend he also has an 3g iPhone, but the question is can i recover an iPhone if it has been flooded, he said he only been in water with it for 2 mins and then it still worked after he got out, this happened 3 days ago. is there anything i can do to fix it, i have 2 other 3g parts iPhones.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Turn it off and put it into a ziploc with dry, white rice for at least 72 hours. That will soak out most of the moisture and give it the best shot at survival.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
If the rice doesn't work then there really isn't going to be much else to do. Replacing all of the damaged parts is likely to prove cost ineffective.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
They're not going to replace it at AT&T or Apple with water damage. They can offer you the replacement price which is either $199 or $299 depending on the size (8GB vs 16GB) but that's about it.
