Need video to DVD conversion program!
K
Kennedy
Guest
Hi guys,
I have some videos of my college’s functions that I want to convert into DVD format for watching it on my big TV screen. I want to share it into my all friends. I am looking for a good software program that can convert my videos files to DVD format. Can anyone recommend me any good program?
Thanks!
termleech
Sep 7, 2007
1,154
McPherson, KS
Do you have a Mac? If so, use iDVD which is part of iLife. If you are using Windows, I think Movie Maker for Windows might do what you want. I'm not sure though.
Khris
Oct 30, 2007
124
Edmonton, AB
I use ULead DVD Movie Factory 6 and have had no problems with it.
D
Doneesa
Guest
Yes! If you are looking for a good software program that can convert your video files to DVD format, xxxxxxx is the right software program you can depend on. With that you will be able to convert any video files you want to DVD format and share it with your friends easily. It is able to convert AVI files, MPEG-1, MPEG-2, MPEG-4, DV and other video file format to DVD format. Hope this will help you.
[FONT=&quot]Good luck![/FONT]
