Needs help
Feb 7, 2009
I have I phone 2G, which was recently unlocked..it worked properly for some time, now I am having trouble syncing with i tunes..when ever i connect my i phone to sync with i tunes it shows that there is no enough space in i phone and it shows that 6.3gb is occupied with 'other'application which i cant find it anywhere. I deleted every picture and application from the phone still i cant find 6.3gb size application.
I wonder if any one can help with this problem.
Feb 7, 2009
I unlocked this phone outside in local shop and he charged 25 pounds..do i deffinatly need to restore and unlock..or is there anything else i can do?
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Try choosing to sync ONLY the checked songs and videos. Then just select one and resync the phone and that might clear up the space in the "other" section. If that doesn't work you may need to restore and you can unlock using QuickPWN .
