NES.app now does sound automatically; allows dragging between buttons A and B
wildonrio
Jul 4, 2007
2,002
Provo, UT
Read about it here. With the new version (Version 0.99.07), the sound will now work without having to disable mediaserverd in Terminal. You DO have to edit one file, but you only have to do it once.
1. Navigate to /System/Library/LaunchDaemons/coreaudiod.plist using Manzana, iBrickr, WinSCP, or the like. Find the part that looks like this:
<key>ProgramArguments</key>
<array>
<string>/usr/sbin/mediaserverd</string>
</array>
<key>OnDemand</key>
<false/>
Now just change that last <false/> to <true/>, reboot, and you're done! Sound will now work automatically every time you play, and you can still receive calls with sound while playing.
If you don't know how to edit files, the programmar already created an edited file for you. You can just download the package via the link above and look for the file coreaudiod.plist. Now just put it in
System/Library/LaunchDaemons/ and overwrite the old coreaudiod.plist.
If you need more specific instructions, let me know. This is just a quick summary.
As I am posting this, the update (
Version 0.99.07) is not yet available at http://pxl.ibrickr.com/ or via the Installer.app, but I'm sure it will be in both of those places shortly :)
To note: This version also lets you drag your fingers to any of the buttons without problems.
EDIT: These instructions used to say </true> instead of <true/> which is why people had problems. They should be correct now.
ANOTHER IMPORTANT EDIT: This guy does his updates way too quick! Now he has version
"1.00_RC1" which does everything I just said automatically! Good riddens.
nobbie
Jul 23, 2007
282
Tapping fingers.
dietPEPSI
Jun 29, 2007
80
Well i did it and there is still no sound.....so i don't know if i did something wrong or you just not right
Conan
Jul 19, 2007
374
ya sound doesn't work :( I did the thing you said and have the .07 version.
Jul 9, 2007
20
yeah me to . no sound. did what you said not working larry ca
wildonrio
Jul 4, 2007
2,002
Provo, UT
Sorry guys, I said </true> instead of <true/>. I edited my OP, let me know if it works now.
Conan
Jul 19, 2007
374
ALL MY SOUND TURNED OFF ; ;! trying the new thing now ...
IT WORKS WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOT
dietPEPSI
Jun 29, 2007
80
still doesn't work for me....
O well...most of the time im gonna be playing this Im not gonna want sound anyway
The Apple
3,105
Indiana
I am still not getting sound. Is there anything else we have to do? Has this worked for anyone?
wildonrio
Jul 4, 2007
2,002
Provo, UT
Did you try replacing the coreaudiod.plist file with the one included in the package instead of doing the editing yourself? I'd love to help more but I can't try this until I get home tonight after work :)
The Apple
3,105
Indiana
I got it fixed. I had to update my NES app. I got sound. You rock the hizzle!:cool:
wildonrio
Jul 4, 2007
2,002
Provo, UT
Did you update to the new Version 0.99.07 first? That's necessary.
EDIT: Now he has version 1.00_RC1 which does it all automatically!
Jul 9, 2007
20
alright got it sound cool larry ca
your on the ball thanks so much
paintdude258
Jul 5, 2007
50
I downloaded the new nes 0.99.07 version, and i have sound but everything is now laggy. what did i do wrong? and how do i get the new 1.00... version because i have the file downloaded from the guys site but i don't know how to upload it through ibrikr
EDIT: nvm, i had to delete my saved game data from my old nes version! now it works fine with sound!
