NES is now totaly perfectly playable! (on the iPhone of corse)
DiscoJoey
Jun 5, 2007
307
0.58 just come out and multi touch is working like a charm thanks to nervegas! If you havnt checked it out you MUST! and if you have tried NES out and hated it because it was so unplayable you also much check it out!
http://iPhone.natetrue.com/nesapp/
Witness
Jun 18, 2007
1,471
29
Miami,Florida
man I would install this so badly but the tutorial is hard and I couldn't even get passed the first step, o well i heard its cool though
DiscoJoey
Jun 5, 2007
307
just install ssh on your phone. for windows this is an auto installer, just run it and follow what it says http://www.modmyi.com/forums/downloads.php?do=file&id=303
if your on a mac here is the auto installer http://www.modmyi.com/forums/downloads.php?do=file&id=337 now i havnt tested the mac auto installer but it should work just like the PC one
once SSH is installed just put the NES app in the /Applications folder and then chmod it and your good to go.
tharmsen
Jul 5, 2007
873
Just do a Google search for "NES ROM" and you'll find sites that have every ROM ever made.
prmdbr
Jul 29, 2007
91
I just hacked this on to my nephew's phone. The control is still rather erratic, but overall this is a solid effort by the community.
Kudos.
hoits2000
Mar 15, 2007
360
Is it NES/ROMs or ROMs/NES?
And I made that folder and used manzana to copy the nes roms into that folder. Now what do I do? Because when I reset it, there are no roms there when I open up the app?
Darth Veneficus
Aug 15, 2007
33
WinSCP
I created a folder ROMs/NES on my pc, put all the roms in there then copied the directory with the roms for my phone.
DiscoJoey
Jun 5, 2007
307
Kudos.
man i think the controls just as good as if you had a real controller now.
and you put games in
/var/root/Media/ROMs/NES
hoits2000
Mar 15, 2007
360
Haha, I go to delete the roms folder and i deleted everything in manzana's right side, had to do a restore and computer reset, duh. Oh well, looks like Im staying stock for a while.
tamakin
Jun 30, 2007
404
DiscoJoey, how do you install this? I just downloaded the auto installer but I don't know how to do this on a mac. Are there step by step instructions?
