Netshare does not show up...
Kaitlyn2004
Aug 6, 2008
72
so I followed the instructions, got netshare.app used winscp to transfer, set 775 permissions and created documents with 777. I reboot and it's not in springboard. Under poof in boss prefa it's shows up with it's icon, and like all others it is set to show.
Any ideas or suggestions? Thanks!
Is it in the /Applications folder?
Kaitlyn2004
Aug 6, 2008
72
it seems when I installed another app through cydia it showed up. Now it seems though that I've lost a lot I interest on using it!
Need to have both wifi and 3g on.. Battery life
Plus I've come across nothing else I REALLY wanted out of an app not available in the app store.. Hmm
Jhors2
Nov 11, 2007
239
I use 3proxy instead coupled with insomnia so it maintains a connection but turns the screen off, it works much better anyways because it keeps the socks proxy on even if you are doing something else on the phone, give that a try instead.
