Network connection issues at setup! Help?
MNJON
Nov 21, 2007
164
9
Minnesota
Wow, this hurts! The new phone is cool... and I was able to activate it and even play with Siri (don't tell my wife)... but, it is not connecting to my wi-fi. It waid the password was not correct so I took the option to continue setup without wifi on. Once all was done and I restored with iTunes.... it will not connect to my network no matter what I try. It wont let me try the password again either.
I tried several passwords before I gave up when setting up, and now when it's all running, it wont show a password option!
Crap, when I put iOS5 on my wife's phone the other day, it didn't ask for the password even! I have not used a password since setting this dang NetGeat WiFi up about 2 years ago. I have no idea what the WEP or whatever security would even be....
Anyone know how I can get into my netgear setup stuff even?
Ugh..... what a let-down.
imamac
Mar 23, 2010
279
You can try to look around in your Router setup page ... try entering either 192.168.1.1 or 192.168.0.1 as a web address and one of them should take you to your router info. From there you may need to login - usually as admin, password admin or password. Some routers give you a place there to change your WEP password.
You may want to re-set your router, too. There's sometimes a little hole where you can push the end of a pen or paperclip to reset it. You'd have to reconfigure your computer's access, too, if you go that route.
BrownGem
Feb 27, 2009
1,623
22
Texas
I had this problem with my iPad2 which I just got yesterday. I typed that long number soo many times. I had activated the iPad and restored from a backup at first. I wiped the iPad and restored as new device. Wifi connected on the first try after the restore.
MNJON
Nov 21, 2007
164
9
Minnesota
What a pain! OK.. well, I did go and reset the router and started over... not as bad as it could have been! Now I better be wise(r) and write down the password! ha ha
Love my 4s!
