network connection with USB
kentsin
Nov 28, 2007
is it possible to use the usb connection as a network? I want to make ssh connection from windows to iPhone through a usb connection.
Doby45
Aug 21, 2007
543
Powder Springs, GA
I don't think it works that way. If you are wanting to use the USB cable and be in a SSH environment you could use iBrickr..
termleech
Sep 7, 2007
1,154
McPherson, KS
I don't think the iPhone has the correct drivers in order to do USB ethernet. There are programs to set up ethernet over USB for Windows (as I use to use it with my Sharp Zaurus), but it's on the iPhone end that prevents it from working. I could be wrong though.
Chris716
Nov 29, 2007
807
IL
yes i don't see it possible to do it that way. Do not have wifi available to do it.
