never unlocked?
Bill Gates
Oct 24, 2007
90
what is the easiest way to downgrade from 1.1.2 to 1.1.1 so i can fake activate it and unlock? please help. getting it tomorrow.
thanks
faseone
Oct 2, 2007
203
Quote:
Originally Posted by enigmanic
Yes, if you're already on 1.1.2, the only current solution at the moment is to downgrade back to 1.1.1, install oktoprep and upgrade back to 1.1.2.
Here's my step-by-step guide to downgrading from 1.1.2 to 1.1.1 using Windows. Please note that this is just a temporary solution, so that you can install the Oktoprep app and upgrade back to 1.1.2. (Big thanks to faseone for confirming that it works!)
Before you begin, you'll need to download the following:
Firmware 1.1.1
http://appldnld.apple.com.edgesuite....a_Restore.ipsw
iBrickr
http://cre.ations.net/creation/ibrickr
Instructions for Windows
Step 1. Dock iPhone and plug into computer.
Step 2. Start up iTunes
Step 3. While holding down the shift key, hit restore. You'll get a prompt box. Choose the 1.1.1 firmware that you've just downloaded.
Step 4. Wait for the phone to downgrade. You will receive an error at the end and the phone will get stuck in restore mode. This is typical. Just exit iTunes.
Step 5. Start up iBrickr. Choose "Boot up Phone". This will kick your phone out of restore mode. After the process is finished, iTunes will start up again automatically.
Step 6. Restore your phone from a previous backup. After it's done, you won't be able to make any phone calls (since the baseband has been changed), but you will be able to use wifi. Using wifi, visit jailbreakme.com to jailbreak your phone.
Step 7. After you've jailbroken 1.1.1, follow the jailbreak guide in my first post to install oktoprep and upgrade to 1.1.2:
http://forums.everythingicafe.com/threads/jailbreak-software-for-1-1-2-released-by-dev-team.14862/
Note: I'm sure the process is almost identical for a Mac Intel, except you hit option+restore in step 3, and would use Independence (instead of iBrickr) to break out of restore mode. Can someone confirm?
THIS IS NOT FOR UNLOCK ONLY TO DOWNGRADE AND JAILBREAK
Bill Gates
Oct 24, 2007
90
Thanks for the quick reply.
and also after i do all that can i unlock it?
faseone
Oct 2, 2007
203
IDK i don't unlock phones.. never have... so I don't wanna steer you in the wrong direction... but thats how I downgrade and Jailbreak....
