New battery guidelines no longer “ABC—Always Be Charging”?
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
Ms. Mooney may or may not be authoritative author on the topic, but her recommendations are certainly different from the last recommendations making the rounds (“ABC—Always Be Charging”). Her source seems credible enough.
Enjoy the article but don’t stop using your own brain when determining how to charge your iDevice’s battery.
https://www.wirelessdesignmag.com/b...hould-stop-fully-charging-your-smartphone-now
Ledsteplin
Oct 29, 2013
4,817
985
65
Florence, AL
The writer doesn't understand how cycles work.
1% to 50% is not a full cycle. It's a half cycle.
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
You noticed that too, huh?
That was peculiar to me, but if you Google “40-80 charging rule,” there are plenty of articles advocating its use. Of course, this could simply be misinformation spreading around.
If you charge an iDevice with extremely low charge remaining, you’ll notice that charging slows down dramatically after around 80% or so. This is discussed in the Apple Support Communities. One reply by a higher level user states that this helps the battery not overheat, so it stands to reason that if you unplug it after 80% is reached, you’re doing the battery a favor.
You may get more total battery life if its charging was comprised mostly of 20->80% cycles instead of 0->100% cycles. Again, I’m no expert, but it does make some sense to me.
Even mophie says (in at least one of its product manuals) that you can make the best use of the charge in its battery cases by using this method (pp. 16-17 of this PDF).
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
Now, if you ask me if I think it’s practical to only keep your phone charged in between 40% and 80% charged at all times, of course, that’s going to be quite difficult, unless you have a lot of spare time on your hands. This would only be possible in a perfect world.
Ledsteplin
Oct 29, 2013
4,817
985
65
Florence, AL
If you do 80%, then the first 20% of the next charge makes it 100% for a full charge count.
