new customize
fsas06
Oct 15, 2007
604
Las Vegas
with the new customize you can change the ipod stars,ipod bar,volume nob and the volume fil "bar: and some phone things like power bar and the bottom bar and call bar
so here is my question lol
i try to open the files(coped to my pc) in adobe photoshop, but it says
"file-format module cannot parse the file" and if i try to open them in jasc paint shop there isn't even a pic.
so how can i get them so i can edit my own ?
AppleSVT
Sep 9, 2007
55
Well you may want to try to find a converter that can change the file to a file that is readable by Adobe or Jasc...just a thought...i don't know what the file format is for those files...check google and see what you come up with
