New iPhone Stand
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Thanks, this is exactly what I need. I was using a home-made thing.
Chris716
Nov 29, 2007
807
IL
i was using the stand i made outa 20 dollar bill that i seen tonight on a thread
iamtko
Sep 18, 2007
2,004
23
Houston
how much is it?
will it work if i have a case on it?
enigmanic
Jun 27, 2007
513
I really want to purchase this stand, but I am hesistant now, after reading to ilounge's review on it. Particularly, this section:
"...Thought Out didn’t fully think through its bottom-of-iphone mounting solution, because the rubber-coated metal grips of the iPhone holder we tested almost completely cover both that bottom speaker and the microphone. You can still get audio in and out of them, but it’s muted relative to the normal, unimpeded performance you get when hand-holding the iPhone or docking it in Apple’s Dock. Callers reported that our voices sounded muffled and distant when we called with Ped3 on the iPhone, and audio output from the speaker was cut roughly in half. Flipping the iPhone around inside the mount is unwise: this just puts continuous pressure on the Sleep/Wake button and covers the headphone port, instead. Surely, there’s a smarter way to hold the iPhone than this."
Of course, that's just one reviewer's opinion. If anyone has purchased this stand, please let us know if your thoughts.
Chris716
Nov 29, 2007
807
IL
yes id like to get a real nice stand instead of the twenty dollar bill im using now
scandalex
Sep 16, 2007
771
After reading this, I went back to look at this stand and I can clearly see how this stand could be a problem. You can see that both the speaker and mic are covered by the rubber grips.
Maybe the designers never thought about that part of the stand being a problem.
Jan 23, 2008
It is not a problem to the degree the reviewer states. Everyone is entitled to their opinion though.
If one notices this issue:
Depending on the placement of the iPhone, the mating area with vinyl protector might clog the most important few holes of the many holes the iPhone speaker has. Please feel confident that a very light bend down or twist out of that one tab will allow the audio to flow efficiently. It will not take much and it will be unnoticed to the eye. Sometimes even sliding the the vinyl protector off and flipping them or swapping them with one of the other six will even correct this, in fact try that first!
(Note: Configuration bending of these tabs is perfectly acceptable to fit your case or skin to the PED3 Stand. These are HIGH QUALITY metal stands, not plastic)
Dec 23, 2007
82
Chicago
www.novembersdoom.com
Someone posted this over at MacRumors a long time ago...
It's a plastic picture frame easel, and it's only $2.99 at Michael's craft store. It's adjustable, and folds flat for travel.
la_ishere
Jan 3, 2008
Lexington, KY
I would have never thought of a picture frame holder but I have to say genius. :cool: Much better than leaving it laying on my desk.
TSheridan330
Dec 16, 2007
56
I don't like the op stand. It looks like that piece of artwork from beetlejuice.
ZipZap
Dec 15, 2007
529
I have a PED-3.
Yeah, it will block the speaker and mic but you can adjust the prongs so that the phone is slightly forward in the cradle.
Also because it is rotatable, the connection point for the holder to the stand is done via a rubber grommeted hole. This make the top piece a but too loose for me.
Finally, they placed their raisded logo sticker right in the center of the holder so the phone would not sit flat...I had to remove it.
$40 is a bit expensive (its more like a $20 item) and it should have come with an additional black cable.
