New iPhone unlock
Nov 22, 2007
Hi is it possible to buy a new iPhone out of the box in the united states and unlock it so it works on Tmobile USA. If so how? Also will it have all the same functions as AT&T.
Thanks in advance:laugh2:
Drtydzn12
Nov 4, 2007
29
yeah. you unlock it yourself, i'm not sure how, but i'm sure others will tell you how. why do you want to unlock it though? I like AT&T better, on my SK3 on T-Mobile, I would always lose reception.
meiphones_brill
Nov 16, 2007
797
No and no , sorry.
If it's New stock that has Firmware 1.1.2 installed, then a the moment there's no unlock available. It will have to be activated with AT&T
Even if an unlock were available it wouldn't have visual voicemail, and will only have EDGE capability as provided by the SIM you're putting in.
If you can find some older stock , then yes - you can unlock it.
Yep, only the older firmware versions will work as of now.
They're still looking for a way to unlock 1.1.2.
