iMac New to iMac
Rafagon
Dec 7, 2011
7,569
1,227
47
Miami, Florida
How do I print highlighted text?
Sent using iCafe app
Hope you enjoy your iMac!
After you highlight the text, press Command+C to copy it to the "Clipboard," and then you're going to have to paste it from there into a text editor or word processor. TextEdit is one text editor included standard with OS X (the operating system your new iMac is running). Go to the Magnifying Glass icon at the upper-left hand corner of the screen, click on it, then type "textedit" in the blank that will appear. Click on the Top Hit, as I'm demonstrating below:
That should put you in the TextEdit Application Press Command+V to paste the text you copied to your Clipboard above.
Now Press Command+P and you'll get the standard OS X print dialog box, which will allow you to select the printer you wish to print to, how many copies you want to print, etc.
Here are some other pages you may find helpful:
Find Out How by Apple
Mail Basics by Apple
Apple ID Support by Apple
Digital Music Basics by Apple
Find Out How: Using Safari by Apple
Download and Install Google Chrome :D by Google
